Mobile earthing
Mobile earthing
A 55kw 415vac Generator will be mounted on the back of a wagon and will be switched on while the wagon is moving.
anybody know of requirements for "earth" protection on
mobile applications
thanks
mobile applications
thanks
RE: Mobile earthing
Its no different than "earth" (or ground or reference) point for the common car or RV (without the generator). The battery and alternators are "earthed" to the chassis.
If you mean by "earth protection" a ground fault protection then all you need is a breaker with GFP relay or trip unit on it. I would not worry about it, if GFP is not already there. Check with the mfr.
