Cut-List-Item Custom Prop
I guess I can NOT insert (even "manually") an equation into the Value / Text Expression column of Cut-List-Item Custom Properties
Am I correct ?
SW2005, SP4.0
Am I correct ?
SW2005, SP4.0
RE: Cut-List-Item Custom Prop
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
But I still can not figure out the answer to my second question ... Here what you see in the Man. tree:
Cut-List-Item1(3)
Cut-List-Item4(1)
I want to get that (3) and (1) somehow - (without braces of course)
Look in API help under "Get Bodies in Body Folders Example (VB)". This may answer your question about getting the body count.
Regg
