"Undo" - what actually gets un-done?
I've noticed some weird things when it comes to the Undo command, and I find it doesn't always undo your last command.
I had one case where I modified a part, and got tonnes of errors, so I clicked 'undo' and it undid something else, and I was still left with all my errors.
What does and doesn't the undo command undo?
phreaq
Has anyone seen my brain today? (^_^)
www.phreaq.net
RE: "Undo" - what actually gets un-done?
Ctrl-Q is a full rebuild from the top of the tree to the bottom... Sketch to feature for every feature.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
It undoes your last action which is not necessarily an "undo command" it could undo the placement of a sketch contraint. Try clicking on Undo List (to the right of the Undo button) to see the list of actions that are available to undo. The most recent actions are at the top of the list. The command works as intended for me in SWx 2005
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
