Removing water to vegetable oil
I've read that it's possible to degum vegetable oil with a membrane. Is it possible to remove water with a membrane?
If so, where would I start?
RE: Removing water to vegetable oil
As far as I know, membranes were first invented for the desalination of sea in order to produce potable water (S. Sourirajan).
Concerning your question, it is a bit confusing, can you please clarify what it is that you want to do?
UF Membranes can seperate water from oil.
Amokbel
Memblog - www.mokbel.ca/memblog.html
