Metal and wet chlorine gas
Any ideas what materials (metal or coatings for metals)can hold up to wet chlorine gas for long periods of time? We have a custmer that needs a sensor that can hold up in that environment. The units he is currently using are not do the job.
RE: Metal and wet chlorine gas
What is he using now?
What is his system built from?
The traditional solution would be a Ni-Cr-Mo alloy (C-22, 59, 686 or similar).
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Titanium also works in wet chlorine gas environment
