Bonding stainless steel
Does anyone know of any good, (hopefully one part) adhesive to bond a stainless steel bracket to a piece of stainless steel sheet metal? Needs to be applied on a vertical wall at room temperature but still adhere at 30 degrees F. Wants to be able to have a shear strength of about 100 psi....
Peter
RE: Bonding stainless steel
Epoxy
Best Adhesive - epoxy
Most important aspect to pay attention to:  the cleanliness of both surfaces (just as in painting, the three most important points are SURFACE PREPARATION, SURFACE PREPARATION, SURFACE PREPARATION).
I've heard of an acyrlic adhesive, Pro-Poly that has a strong lap shear strength bonding to steel.  It is a two part adhesive so I'm not sure if you would be interested.  Surface preperation is key.
Try pliobond 20 or 30
works well with galv steel sheets.
2thumbsup Mech Rulz 2thumbsup
