Danger of compressed air.
I am trying to quantify the amount of potential energy created when compressing air. Specifically related to the volume of air compressed.
Example:
A vessel is being hydrostaticly tested (water), but has air traped inside. It is pressured to 2000psi.
Scenario #1: pressurization occurs with 1 cubic inch of air.
Scenario #2: pressurization occurs with 1 cubic foot of air.
Is one scenario more dangerous than the other (more potenial energy) and if so, how much so?
Are there other factors to take into account?
I only know enough that i don't want to be around if a vessel containing a compressed gas was to let go.
Thanks in advance for you input.
Example:
RE: Danger of compressed air.
The energy in the trapped air is simply V*P. Where V, in inches^3 is the volume of trapped air and P, in #/in^2 is the pressure. That will give you the potential energy of the trapped air.
With air the pressure vessel will explode like a bomb and scatter schrapnel all over the place. With water it will simply rip open and you will get wet.
In either case do not be in the area of the test item.
Dave
http://www.combro.co.uk/nigelh/diver/tank.html
There are a few ways to calculate the energy you have available. To get a good feel for it you need to incorporate time into the formula. The length of time will depend on the size of the orifice or breach.
Barry1961
10 psig-1154.6 ft-lb
20 psig-1971.4 ft-lb
50 psig-3619.8 ft-lb
100 psig-5327.9 ft-lb
If this work was done or expended in a short period of time the results would be note worthy. Of course the actual damage would depend on several factors.
Barry1961
Our rule of thumb for compressed air is anything discharge (explosion) over 3 PSI of compressed air and projectiles will break skin. We keep our pressure testing in house to 3 PSI and if we require higher pressures we use water, grease or hydraulic oil.
Tofflemire
