Maximum velocity for gasoline through an hose?
Hi everyone,
I'm looking to find the maximum velocity that I can have in a hose...Someone has an idea about that?
I have found that the maximum velocity for 8 inches hose is 15 meters/second, but I bet that for gasoline, the velocity must be lower...( presence of electrostatic charge generation)
API or anything else that can help me...?
Thanks you
Ken
Thanks you
Ken
RE: Maximum velocity for gasoline through an hose?
Thanks for your answers...
HAZOP at www.curryhydrocarbons.ca
I do not have API 2021 on hand. However, the maximum velocity limit of 3 ft/sec (1 m/s) seems too low for me. I believe that the discharge line of pump always design with higher velocity.
KenBilodeau,
-What is your required flow rate?
-How about the velocity in your line size 10" or 12" in other sections?
-What is your required flow rate? in the future 1400 m³/hr
-How about the velocity in your line size 10" or 12" in other sections? @1400 m³/hr, we'll get about 17 and 25 ft/sec.
Anyway, I have called the manufacturer and he told me that the "extreme" velocity limit is about 50-60 ft/sec (depend of the standard's indutry). BUT, for security and the hose's lifetime, he recommands a lower velocity, like 35-40 ft/sec.
Ken
I assume that you use carbon steel pipe size 10" and 12" in the line. In my limited experience, the velocity 17 to 25 ft/sec will be a cause of high erosion.
Your future flow rate is 1400 m3/hr. How about the current flow rate?
For security and for pressure drop, we don't want exceed 25 ft/sec in normal piping.
A106 - Grade B
In my opinion, your current facilities and actual flow should be acceptable.
If you increase flow rate from 650 m3/hr to 1400 m3/hr, you should increase your line size (and hose also). Velocity limit is for rough estimation only, however, I will not recommend to use even 25 ft/sec. This is still high velocity limit for me.
