70-80%
70-80%
In a technical manual is it correct (preferred) to state 70 to 80%, 70-80%, 70% to 80% or 70%-80%? Internal arguments and personal preferrences have prolonged release of this document for this trivial matter.
RE: 70-80%
That should be covered in the company's style manual.
If none exists, let the highest ranking gorilla choose, and use that convention consistently.
Mike Halloran
Pembroke Pines, FL, USA
RE: 70-80%
I prefer to use the tilda sign 70 ~ 80. The sign - could be assumed to represent a minus.
RE: 70-80%
Thanks for the replies; the problem lies in the "highest ranking gorilla" battle. I'll choose and release.
RE: 70-80%
Just make in unambiguous.
In all of your examples (recognizing that they are presented out of context), it is not clear if 70% or 80% exactly would be acceptable.
RE: 70-80%
I would keep it consistant with how others are designated, i.e. temp, length, etc.
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: 70-80%
The most important thing is to get your meaning across clearly and unambiguously. Worry about style afterwards!
RE: 70-80%
As an example, the SI style manuals have the following requirements:
(70 to 80) %
70 % to 80 %
Cory
RE: 70-80%
70 % to 80 % is the only unambiguous one
eg, what does 3-5k V mean? (particularly when spoken)? is 3V acceptable?
Cheers
Greg Locock
RE: 70-80%
Even "70% to 80%" could be ambiguous; i've seen those noted "70% to 80%, inclusive".
Isn't there some kind of convention that ranges are inclusive unless otherwise noted?
Hg
Eng-Tips policies:  FAQ731-376
RE: 70-80%
If one adds the word range the ambiguity disappears. Right ?
RE: 70-80%
Within the 70% to 80 % range could include values close to that range i.e. 69% or 81%
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
RE: 70-80%
==> Within the 70% to 80 % range could include values close to that range i.e. 69% or 81%
Is that what they mean by "New Math"?
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: 70-80%
dgowans - Yes, they are different, but in this case, I think either one is acceptable.  You should be able to replace 'i.e.' with 'in other words', and 'e.g.' means 'for example'.
Good Luck
RE: 70-80%
Agreed.  I looked at this again after I posted and realized that either abbreviation worked in this case.
RE: 70-80%
75% +/- 5% with a 95% probability.
clown
saludos.
a.
RE: 70-80%
Oh, so 0% is acceptable?
Cheers
Greg Locock
RE: 70-80%
>70% & <80%
RE: 70-80%
Forgot to add the shall word for the earlier post.
The operator shall ensure % total liquids shall remain in the range >75%&<85%
RE: 70-80%
70 ta 80% more or less.
RE: 70-80%
In our technical literature, we always use a "triple point" to indicate a range. Like this:
70%...80%
The percentage sign belongs to the number, because what you are writing is actually:
70/100...80/100
If units are nedded, they would be placed at the end like this:
70...80 V.
Regards.
RE: 70-80%
Use an N-dash, rather than a hyphen:
70–80% instead of 70-80%
Fred
RE: 70-80%
Yeah, but some big hairy gorilla (Gee, with all the RFs flying around is this PC?) just might read that as 70, less 80%.
RE: 70-80%
I think in punctuation ..., ***, - marks indicating a pause, or omission of obviously understood words, are called ellipsis.
