SW Piping module for semiconductor use?
Has anyone used the SW piping module?
I design Gas control cabinets (mostly 1/4" tube) of about 500 parts in Autocad 3D.
I'm new user trying to use SW to do this and am not making much progress with assemblies.(Although its great for machined parts)
What have you been through doing 3D piping?
All sugestions welcome
RE: SW Piping module for semiconductor use?
Check with your Solidworks VAR for this.
Otherwise, you will have to do it all manually using the 3D sketcher.
I just built a large (to me) piping assembly of Pvc pipe for a riser washer station. This assembly was of course automated and seems to work fine. We have the piping add-on here and I Did Not use it. I made all the pipes manually and I did not saved them in the palette parts. I saved them in their own file folder due to the fact they where in-contexted to the asembly and other parts of the assembly. Otherwise, I would have saved them for future reference.
You can try using the 3D sketch for making pipes with. Although if your having problems with assemblies then you will probably have problems with this then too.
If you would like I could send you a file of some pipes made manually and assembled. Also made by using 3D Sketches.
Hope this helps,
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
