G Series holes in Hole Wizard
Has anyone out there created a custom Hole Wizard database for G Series British Straight Pipe Thread holes? I have been trying to do this based on the ANSI Inch standard, but I am not having any luck. The format seems fairly straight forward, but I never seem to get the desired outcome. Either the hole or annotation dimensions are not correct or I seem to loose some parameter and end up with a 0 diameter hole.
I was able to create two custom databases for dowel pin holes, based on ANSI Inch plane holes, but the threaded hole format has me stumped.
RE: G Series holes in Hole Wizard
For G Series British Straight Pipe Thread holes try:
DIN / Straight pipe tapped hole
Ciao
Well Jeez, would you look at that! I searched high and low and completely miss that. Thanks morsa70.
