SolidWorks menu customization
How do I add a menu category and a menu item to SW menu?
Andrew(Netshop21)
RE: SolidWorks menu customization
From my understanding, you will need to learn how to use C++...
I maybe wrong! Would someone care to comment on that?
Cheers,
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
SBaugh is correct.
Once compiled, you will have to run the Add-In Manager
to register it with Solidworks, additionally the .dll will have to be registered with your system.
Otherwise, VB may be the way to go instead of having a menu item directly in SW.
If you want to use VB, you will have to cheat. You can assign a macro button to a program that will present your menu, in this case a form that has your items on it. Like SBaugh and jmagee indicated, you will need C++ to add menu items.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
