Carrier E20 hap software atrium heat load calculation.
I have a atrium (half pipe glass roof).Software wants only two dimension for skylights.If I use only to dimension ,roof area will be projected area and will be less than actual glass area.(In my problem there is %20 area difference).If I use actual glass area ,This gives also wrong result because solar radiation area is the projected area.Which area must I use.Thank you in advance
RE: Carrier E20 hap software atrium heat load calculation.
This should give you a reasonable approximation for your system geometry.
