Cured-In-Place-Pipe - Sewer Repair - Cross Post
Does anyone have experience with CIPP? Our client has a break in a PVC pipe, 9 feet below grade and, unfortunately, 4 below a column footing. I'm hopeing to avoid all of the shoring that would be necessary if we dig. Hence, I'd like to use one of the "pipe within a pipe" solutions.
Q1) do these work long term?
Q2) does the heat of curing effect the pvc pipe?
Q3) difficulties of installation?
Thanks in advance,
Thanks in advance,
RE: Cured-In-Place-Pipe - Sewer Repair - Cross Post
It used to be that you would have to line from access to access point, I.e., manhole to manhole, but now there are sectional point repairs that can line a small section.
Be careful, as there are now many players in the field. look at experience and dont forget to consider loss of diameter and structural capability of the repair. I would start with a search on INSITUFORM as they are the original product in the US.
We have talked to InSituForm and Inliner. Because we are going around one 90 bend and cannot make it to another manhole,i.e. blind shotting, InSituForm has bowed out. In order to get to the next manhole we would have to go through another 90 bend. All three of the companies to which we have talked have said that they can't do (2) 90 bends in such a small diameter pipe (8
Imagineer
All three of the companies to which we talked said that they can't do (2) 90 bends in an 8" pipe. It would seem that this can't be the first situation requiring a 90 bend. Is the problem the small diameter of the pipe?
TIA,
Imagineer
