How can I make to drive the gears?
Hi guys!
I've read throught the topics, but i couldn't find answer to this question. I would like to make a gear system, where each of them drives another component with their cogs. So how can i bulid a mechanical system with real physical effect (gravity, friction)
If somebody knows this, please answer to me, because it's very important for me.
Cheers, Bajszi
Cheers, Bajszi
RE: How can I make to drive the gears?
If you want that, you will need to look to a 3rd party such as LMS' VirtualLab.Motion or MSC's ADAMS.
Thanks for the answer. But still I don't know something. I understand that I can't work with friction, mass, forces. But if I wanna bulid a gear system, and I would like to give the spin to the first gear, and after the second gear should be spinning by the first gear, and after the third should be spinning by the second, and so on...
For example... is it possible to create a car-gearbox? So I would like to drive some gears with only one gear.
Cheers, Bajszi
It's a simulation, though. It does not actually use the contacts of the gear teeth. If you line the gears up right, and specify the correct ratio, however, it should look good.
Cheers, Bajszi
