electro mechanical relays
What is the difference between a HCB relay, and a PMA relay? Don't the both monitor pilot wires between substation?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: electro mechanical relays
HCB:
http
(copy and paste whole address)
The type HCB relay is a high speed pilot wire relay designed for the complete phase and ground protection of two and three terminal transmission lines.
PMA:
http
Type PM and PMA Monitoring Relays provide continuous monitoring of a pilot-wire circuit to detect open circuits, short circuits, grounds, and wire reversal.
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
If memory serves me right, you need both an HCB and a PM-1 at each end (4 relays). I remember the HCB takes the input of the three phase currents at one end. The PM-1 somehow helps with the interface and transfer trip function.
