Help with Network Toolbox Set-up
We have about 10 users running SW2005 SP3.1, everyone running a stand alone toolbox off their local drive. You can understand my frustration.
I executed the instructions per past posts and SW website in regard to;
- copying the toolbox folder to our server
- editing the toolbox.ini file
- setting the 'read-only' flags.
This did not work. It couldn't find the browser, so I copied the contents of the browser directory over to the server. It then asked for the master database. Copied SW\lang\english\swbrowser.mdb file to the server and viola it finally connected.
When I drag a toolbox part into an assembly I get the following error message window pop-up "Called Force ReleaseLocks!!!". Anyone know what this means and what is it's impact? Did I do something incorrect?
Another General Question;
Has anyone done this successfully before? What I ultimately want are seperate lists of Socket Head Cap Screws for Steel, Stainless Steel, Hardened Steel. Can this be achieved?
Thanks in Advance
Jeff Martin
Thanks in Advance
Jeff Martin
