Bearing Failure Analysis Software
5
I have recently been given the responsibility of analyizing the cause of bearing failures for all different types of bearings.  I have some experience with this, however, if there is some software or downloads available with photographs that I can obtain for comparative analysis, it would be very helpful.
RE: Bearing Failure Analysis Software
LT22:  Bearingf manufacturers sometimes provide illustaions and possible causes of bearing failures.  Start there
Dave
Try posting your request to:
Bearing design, manufacture and maintenance Forum
I have a great report that explains bearing failures.  It is very comprehensive with plenty of illustrations.
It is from EPRI (Electric power research institute)
Perpared by Mechanical Technology, Inc Latham, NY
Report #:  GS-7352
Project #: 1648-10
July 1991
Hope this helps.
CODE
http://www.fag.com/content/media/_shared_media/library/downloads/downloads_fag_temp/wl_82102_2_de_en.pdf
http://www.fag.com/content/media/_shared_media/library/downloads/downloads_fag_temp/ti_wl_80-60_de_en.pdf
http://www.ntnamerica.com/Engineering/PDFs/Other/3017cat.pdf
To start wiith.
Those handheld bearing analysers are regarded to work very well.  A scan with a heat camera will also tell of problems to come.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
LT22, I did some search on my bookmarks and google, the most usefulls are:
Bearings Reference Center by Machine Design:
http://www.bearings.machinedesign.com/
An Introduction to Ball Bearings:
http://www.ntnamerica.com/Knowledge/Intro_Ball_Bearings/Ball_Bearing_TOC.htm
Bearing Failures & Their Causes:
http://www.vibanalysis.co.uk/technical/contents.html
Bearing Failures:
http://www.materialsengineer.com/DA-Bearing-Failure.htm
Reducing Bearing Failures:
http://www.mt-online.com/articles/0603uvlm.cfm
Rolling Bearings Troubleshooter's Guide on CD-ROM:
http://www.engineeringbookstore.com/cds/Rbtg-cd.htm
SKF Maintenance Products:
http://www.mapro.skf.com/index.htm
SKF Precision Technologies - Engineering Handbook:
http://www.rtgilman.com/handb/handframes.html
