Retaining Wall Question
Does anyone know the difference between Cantilever and Lagging Retaining Wall?
RE: Retaining Wall Question
A cantilevered retaining wall can be constructed in a variety of ways. it may be a gravity cantilevered wall or a nongravity cantilevered wall. The difference is that the gravity cantilevered wall is roughly shaped in cross-section like an upside-down 'T' (sometimes called a semigravity wall). The other type is shaped like an 'I' in cross-section.
Gravity walls (including semigravity walls) are generally cast-in-place concrete.
Nongravity walls may be comprised of continuous or interlocking elements such as sheet piles or secant piles, or they may have discrete vertical elements, such as H-piles, with horizontal panels or planks (lagging) spanning the distance between adjacent vertical elements.
Hope this helps.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
Lagging refers to the type of wall design. Sheeting can be steel sheet piles which are Z shapes when locked together form a couragated wall, or soldier pile and lagging. This consists of piles driven at some distance apart, typically 8 feet, along a wall line. As the excavation progresses, wood boards,2- 3 " thick 8" wide are inserted betweeen the flanges of the piles, forming a solid wall. Either wall system can be cantilevered anchored or braced.
