Draft template problems
A few weeks ago I discovered all my draft files take a long time to load. I discovered the template I created contains a link to a .gif file on my server. The server was replaced at this very date I noticed the problem and has a new name so SE searches in vain,a long time for something that is no longer there. I can't remove link, change link or recreate server link.
I created a new draft template which works fine. However all my old drafts are suffering with my past sins.
Any ideas? Could I change old template for new?
RE: Draft template problems
Have you tried Edit > Links in the draft file ?
bc
When I try to change link to another location SE cannot recognise .gif file I am attempting to substitute.
For each draft file that load slowly, for now create a new file with that old .gif file name so SE has something to find rather than waiting to time out. Then, in each draft, just update/remove/replace the old .gif image (I'm assuming a logo on your title block) with the new one the same way you fixed your new templates.
--Scott
For some pleasure reading, try FAQ731-376
