Dialog Boxes opening .iges
Hello ;
 Does anyone know the System variable to open the dialog box when using the "igesin" command on the command line.
 Having a problem with the iges editor asking me for "file name" instead of opening a dialog box to Browse to the .iges file I need to open.
 When we open .dwg files the dialog box opens but not for igesin
   Also ; Where can I get info . about problems with .iges, we transfer alot of files from Pro "E" and "Esprit"  G code .
                    thanks
                         Mark
RE: Dialog Boxes opening .iges
CMDDIA?
ADT 2004
ACAD 2002
Thanks Exit thiat worked fine....Mark
