round HSS or sched 40 pipe connections: good textbook?
Hi all,
You may have discovered that AISC's Hollow Structural Sections Connections Manual is very thin.
Can anyone recommend a good textbook on designing connections where schedule 40 pipes or round HSS meet?
In particular, I am designing steel trusses using pipe shapes. I need a design manual to check the connections where different size pipes meet at K-joints. The top and bottom chords are continuous.
Thank you,
Mike
Thank you,
Mike
RE: round HSS or sched 40 pipe connections: good textbook?
