Knurl on cylindrical surface
How can I create a knurl cut on a cylindrical surface? in the part modeling. Please help.
RE: Knurl on cylindrical surface
Why would you want to waste your time modeling a knurl.  I would just add a surface texture.  Are you using Wildfire or Pro/E 2001?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
I agree with Heckler. There is no need to show an actual knurl on a surface, unless it is for a photorendering or some other type of presentation. Adding such features with actual cuts only helps to slow down your regen time.
If you really, really, really need to make a knurl (diamond shape I assume), then you can project or revolve a datum curve around the cylinder surface, then make a swept cut and then pattern the datum curves and cuts. Do the same thing for the other direction.
There are other ways to do it with surface also.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
One other way to go about it is with a helical sweep. Make sure you sketch the sweep profile on a Make Datum that is offset at an angle, as this will allow you to pattern it radially. You will need two patterns, one from a right handed helical sweep, and the other left handed. It's basicaly the same thing as Steve's suggestion.
I also agree with Heckler though, knurls make for slow regenreating models. Applying a texture with a bump map would probably be the best way to go about it.
Thank you for all your help. I agree. the surface texture is the best.  I am using ProE wildfire 2. How can I create a surface texture on cylindrical surface. Please advise.
