Create solid from complex surface
I have a surface model composed of 3D faces, from a tin, and would like to add some "depth" to the entire surface. Is there anyway to "extrude" all these surfaces at once in one direction to create a solid? I am trying to model a tunel through a montain and want end up with two solids, one for the "solid" surface and one for the tunnel geometry, and subtract the two. Any other approaches are welcome as well, I am fairly stuck on this one.
Thanks a lot
Thanks a lot
RE: Create solid from complex surface
Depending on your requirements, you may be able to extrude a section along a path to recreate the "tunnel hole"
Dambuilder
