Getting solid models online
I do my 3D Modeling in Inventor 10, and would like to get these solid models online. I want people to be able to download the solid model, and rotate it as needed. I'm relatively new to the process, but have been experimenting with .stl extensions, but that seems to leave the model completely unconstrained, even if I myself open it. Also, in one attempt at an assembly, I even ended up with all the parts merging into a single part, which was very odd.
The next step would be allowing the downloader to move the parts of the assembly that are allowed by the constraints, i.e., for a simple example, if there was a bearing around a shaft, the bearing could still rotate in their model.
Lastly, the mostly complicated goal (I dont know if it can be done) is to allow the downloader to download a single assembly, but by suppressing some features and unsuppressing others, have them be able to be able to look at multiple versions of the same product.
The primary goal is to get the solid models online and able to rotate. I'd appreciate any help I can get, or even a kick in the right direction. Thank you,
JasonE
JasonE
RE: Getting solid models online
Regardless, there is no way to open the dwf in a solid modeler or other cad program and "steal" any design intent.
Obviously SW2006 hasn't seen the recent versions of the .dwf format....they have a lot to offer, and although I haven't seen an e-drawing since release 2004 the new .dwf is certainly better than that....but we don't need to get into a comparison discussion (that's been done other places many many times)
You can also use the VRML format and publish your assemblies to .wrl files (can be viewed online using any VRML browser) - see:
http://www.aac-solutions.cz/en/vrmlout.asp#AI
V.Michl
