SW keeps opening entire Asm.?!
Hello
I have just installed SW 06 Sp1
and whenever I open a part the entire assembely opens!
I have been told to try :
"Tools/Options/System Options/External References/ Load referenced documents dropdown
The choices are
Prompt
All
None
Changed Only
My system is set on Prompt
Maybe yours is set to ALL"
That didn't work either
Any suggestions ?
Thank's in advance
Tony
RE: SW keeps opening entire Asm.?!
1) Try changing the setting on that option to "Changed Only."
2) Try to break the external reference unless it needs to be there for a reason.  (Even if it does, can it reference an assembly or a part at a slightly lower level?)
