Calcn. of Displacement, Velocity & acceleration
I just want to know, if acceleration displayed on vibration analyzer can be directly divided by angular velocity of the shaft in order to obtain the value of veloity(mm/sec)and similarly for displacement(velocity/angular velocity of the shaft).
RE: Calcn. of Displacement, Velocity & acceleration
g=0.641*V*f
and
V= pi*f*D
where V is velocity in meters/second
and D is displacement in meters pk-pk
and f is the frequency of the sine wave in Hz
I'll leave it to you to convert from meters to mm or microns.
http://www.wilcoxon.com/know_calculator.html
Regards.. kv
thanks for the information, but i have a small suggestion to make. Foll. is the formulas displayed in u'r website,
I think wherever 103 is displayed it's 10E+03, which otherwise could be misleading.
But for the rest thank you,
sicerely,
Kashyap.
D = Displacement, P-P, Mils.
V = Velocity, 0-P, in/sec.
A = Acceleration, 0-P, g's.
D = 19.10 x 103 x (V/CPM)
D = 70.4 x 106 x (A/CPM2)
V = 52.36 x 10-6 x D x CPM
V = 3.87 x 103 x (A/CPM)
A = 14.2 x 10-9 x D x CPM2
A = 0.27 x 10-3 x V x CPM
The first response correctly pointed out that any such conversion only holds for a single frequency (the conversion is frequency-dependent).
Subsequent formula's would be correct by substituting f=shaft angular velocity IF AND ONLY IF the acceleration is due soley to vibration at 1x running speed. Such vibration is common, but sometimes the predominant vibration may be 2x, 3x running speed etc (for misalignment, blade pass, gear mesh etc)or even a non-syncronous multiple of running speed (for bearing problem).
Judging from the questions you've been asking, you might want to invest in a text on the subject.
good observation & analysis,
keep - it - up!!!!!!!!!!
cheers,
kashyap
Also try out the freeby download at
www.mpiuk.co.uk/vibsliderule.htm
Enjoy!
