IGES Batch translator utility unable to function
We have purchsed an Autocad mechanica 2006,and it was asked along with a IGES batch translatoro utilty.
But IGES batch translator is unable to function. It is unable to find the required files for it,even if you provide them it comes with a failure that profile is not correct.
Reseller of Autocad says this utility is only for Autocad inventor professional software and not for Autocad mechanical 2006. Is it true?
Does any body have IGES batch translator working with Acad mechanical 2006. Do we need to make some work around for it.
RE: IGES Batch translator utility unable to function
Place the ADXBATCH executable in your search path
 The degtools directory contains this standalone executable tool. To run ADXBATCH from any directory, include the degtools directory in your command search path, or copy the executable to a directory that is already in your command search path. For details on how to specify a search path, see your operating system's documentation.
Create a batch file to launch AutoCAD
 ADXBATCH requires that a batch file called acad-deg.bat be present somewhere in the system path in order to run AutoCAD. You must create this file. See IGES Translator tools for further information about how to create it.
"Everybody is ignorant, only on different subjects." — Will Rogers
Thank you.
It works, I come across an error message.
i.e   A bad profile is specified in the command line
     files\autodesk\acadm
     The current profile name in the registry will be used
After clicking OK to this message, I could translate.
Please tell me how to get rid of this error. I have several files to be tranlated and it makes no sense to click every time "OK" for this error for every file.
