From Delta to Wye, concerns.
I am running a 15 Hp motor rewound from 480 only to run on 230 delta off of a roto phase. As we are installing 120/208 wye, we would like to reconfigure this motor for the new service type. Is this a problem that can be addresed by reconnecting the motor field and stator leads? As the leg voltages are different on delta than "Y" (no high leg) I presume the excisting connections wouldnt be right. Would anyone care to comment on this issue. Hoping the motor won't have to be rewound for a second time. Only wye type supply is available in our area. If a rewind is a must, would a transformer on one leg for boosting puposes be a cheaper option. Thanks in advance for your thoughts.
RE: From Delta to Wye, concerns.
Most 480 volt motors are dual voltage 480/240. Did you really have it re-wound or just reconnected at the motor terminal box?
Don(resqcapt19)
