Insufficient bar joist bearing
I am investigating an existing building (approximately 1 year old)which has a roof system of bar joists/girders. One particular joist bears only 1-1/2" on the girder. The bar joist specifications require a 2-1/2" bearing. There is another joist on the opposite side of the girder at this location with sufficient bearing. Is there a way to reinforce the "end" of this joist or should I add a "seat" to the girder to obtain the required bearing?
RE: Insufficient bar joist bearing
That's usually caught by the inspector, if there is one.
I have seen this done on past projects and it works fine.
I am curious why are you investigating a one year old structure?
Lutfi
