SAE J429 materail spec or bolt spec
Does SAE J429 specify a material properties and bolt properties or just bolt properties. (i.e. can I purchase a non threaded SAE J429 rod or would it be a ASTM AXXX steel) I seem to get conflicting responses from coworkers. Any help would be appreciated.
RE: SAE J429 materail spec or bolt spec
title is:
Mechanical and Material Requirements for Externally Threaded Fasteners
note:
TABLE 1—MECHANICAL REQUIREMENTS AND IDENTIFICATION MARKING FOR BOLTS, SCREWS, STUDS, SEMS, AND U-BOLTS(1)
and:
TABLE 2—CHEMICAL COMPOSITION TEMPERING TEMPERATURE AND IDENTIFICATION FOR BOLTS, SCREWS, AND STUDS
a) medium carbon steel (medium carbon steel w B or alloy steels also acceptable) with 0.28-0.55 mass percent C.
b) quenched & tempered with minimum tempering temperature of 427 C.
c) P = 0.030 max & S = 0.050 Max
Typical grades are SAE 1035 and 1541.
