Unbonded topping slab thickness
I am designing a building which has part of the second floor as a balcony over an enclosed space. The Architect is showing the balcony as my composite deck and slab system with a waterproofing membrane and an unbonded topping slab on top of this which slopes to a drain. I was going to make the minimum thickness of this topping slab at the drain as 2 1/2". Does this sound satisfactory? The live load on the balcony is 100 psf foot traffic. Thanks.
Dan
Dan
RE: Unbonded topping slab thickness
