Update drawing to New Standards
If I have made changes to my drawing standard, how do I get my drawings to update to the new standard?
RE: Update drawing to New Standards
I have changed my standard after creating my titleblock, but the original settings from the titleblock creation are staying active.  How do I convert the titleblock drawing to the new standard, so that all my drawings use the new settings.
Hopefully I have explained my situation clearly.
File, Page Setup, Update should do it.  That does not, however, change everything already existing.  For most drafting elements, it simply changes the defaults (and allowable parameters for modification).
I'm not sure how to fix your titleblock drawing.  We use a script to create the titleblock on the fly.
