Polysulfone with Corrosion Inhibitors
We've been seeing some deterioration of polysulfone fluid handling fittings used with Antifrogen N systems and other liquids containing corrosion inhibitors.  Failure usually is by cracking and flaking of the material, especially under stress.  I -guessing- it's caused by chain scission- maybe some salt splits the polymer chains in two.  Has anyone else had a similar problem?  Does anyone know which particular corrosion inhibitors need to be avoided with polysulfone?
Thanks much,
Jeremy
