FlexGrid Doesn't Work
If I add the MS FlexGrid Control, and click on Custom properties, it errors out, saying I can't add it during design, or the ActiveX control isn't loaded correctly or some such.
What is really wrong? If it is not loaded correctly, what put it on there, and what do I need to reinstall?
Thanks in advance
Thanks in advance
RE: FlexGrid Doesn't Work
Perhaps someone who has VB built the application, and if you don't then that is the problem.
If you do then check your VB installation.
Mike
