Equivalency of random vibration and sinusoidal vibrat ion
It is recognized that there is no "real" equivalency between random vibration and sinusoidal vibration. However, are there are any empirical equations based on tests or analysis that provide "approximate" equivalency between random vibration and sinusoidal vibration ?
RE: Equivalency of random vibration and sinusoidal vibrat ion
You can measure the average RMS of the random signal and then use 1.414 for the value in 0-pk at the dominant frequency.
Lunney & Crede (see WADC TR-56-503) showed that by assuming Rayleigh distribution of the peak accelerations and combining this with Miner's rule of equivalent damage, the equivalent sinusoidal response acceleration, Aeq is given as
Aeq = Q*Ar
where Ar is the RMS random vibration response acceleration
and Q=[(0.5*(2pi)^.5)^(1/(lambda*alpha))*(lambda*alpha/e)^0.5]
where
lambda = a constant based on experimental data
alpha = slope of the fatigue curve when plotted in log-log coordinates
e = 2.718281828...
Long story short, Q = 2.14-2.17 (usually taken to be 2.14) for most metals.
Jeff Strain
jeff.strain@padtinc.com
Phoenix Analysis & Design Technologies
