Water main design for small subdivision
I am trying to model the water distribution network for a small subdivision and check fire flow pressures, etc. For the mains that we will be tying into we have the following information at hydrant locations: static pressure, residual pressure, calculated flow, and measured flow at 20 psi. How do I take that information and use as input it in either Hardy Cross or EPANET to model my system?
RE: Water main design for small subdivision
Good luck
