find references macro
does anyone know of a macro that will find the references and copy the files for a part? Its rather tedeous to have to go through every part and do it manually.
RE: find references macro
mAX,
In your assembly you can click File, find references, and then copy the files.  This is very easy.
dsgnr1
At some point you just have to shoot the engineer and build the dang thing.
well yes, I know, it is relativly simple, however its fustrating when you have to do that 50 times over for each project everytime it is updated, my main contention here is that all this work is almost completely non creative, and as such could be handled by a macro.
so it really is an assembly, rather thatn a part that you wish to find the references...then you want a macro to perform this.
Have you looked at the faq's under vb or programming or whatever they're calling it now?
Have you searched this forum for links to sample code?
these things (unlike my first reply) may help.
regards,
dsgnr1
Quote (nmaxwell):
Sounds like what you want need is PDMWorks.
Flores
SW06 SP2.0
You can do this very easily through a macro with a rudimentary understanding of the SOlidworks API:
1) Use "getDependencies2" method to return an array of all referenced documents in the assembly
2) Using your preferred VB copy method (FSO works well), use the names obtained in step 1 (odd numbered elements will be the full path names if you start at 0) to copy the files where you want them to go
Loop through it again to copy multiple assemblies.
alright so I take it there arent any such macros already, im sure its fairly simple to do, once i get some idle time ill look into it thanks, and we do use pdmworks.
