IDE / SATA drive, how to set it up
Hi, I have a Gigabyte GA-8I848P motherboard with 2 IDE hard disks. One of the disks has just died so I thought I'd get a SATA disk to use a primary and keep the remaining good IDE disk for data storage.
Does anybody know if this is possible to do (Run SATA and IDE together), are there any special settings I need to set in the BIOS. I've looked at the instructions but it just states:
On-chip SATA
Disabled Disable SATA controller.
Auto When no dev ice is plugged in IDE1 or IDE2, SATA controller will remap to IDE
controller. (Default v alue)
Manual Set SATA Mode manually.
SATA Port0 Configure as
IDE Pri. Master Remap SATA Port 0 to IDE Pri. Master.
IDE Pri. Slav e Remap SATA Port 0 to IDE Pri. Slav e.
IDE Sec. Master Remap SATA Port 0 to IDE Sec. Master.
IDE Sec . Slav e Remap SATA Port 0 to IDE Sec. Slav e.
SATA Port0 SATA controller set to SATA port0. As this mode, it support by WinXP or
later OS only . (Default v alue)
SATA Port1 SATA controller set to SATA port1. As this mode, it support by WinXP or
later OS only .
SATA Port1 Configure as
The v alues depend on SATA Port0.
Any Ideas.
On-chip SATA
later OS only .
Any Ideas.
RE: IDE / SATA drive, how to set it up
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
