Catia V4, Curve 2 Connect
In Catia V4 under Curve 2 Connect, what exactley does it mean when you highlight the crosshairs at the ends of the connecting curve. I was told that it made it tangential, but not highlighting the cross it's still tengential. Any Idea's?
RE: Catia V4, Curve 2 Connect
Ths cross is for the Curvature continuity, the arrow is for tangency if it is highlighted then it is ON, if cross and arrow are OFF then you just have point continuity.
