ACAD - COORDINATES DISPAY
IS THERE A METHOD TO CREATE MTEXT (OR 3 LINES OF TEXT I GUESS) DISPLAYING CO-ORDINATES (AND ELEVATION), GLOBALLY FOR MANY POINTS. THANKS.
RE: ACAD - COORDINATES DISPAY
Sure, it'll require some code but if you can be more specific we can probably help you out.
HTH
Todd
All I want to do is basiclly show the xyz attributes in text by the side of each point, without going point to point manually (talking often 100s of surveyed points).
http://ww
Both CarlB, and lpseifert are right, so the question is do you have old drawing you need to do this with? Or do you still have the old data files. Finally, how do you get your point in? Is this custom software you've written, or is some canned application you wouldn't be able to modify?
Let us know!
Todd
I import the points from NovaPoint Terrain Model to Autocad as points - I guess the question is converting these points to blocks, if ,as you say CARLB, the then display of their attributes is fairly straight forward.
So how do I convert the points (globally) to blocks and also do you have the LSP which will then display the attributes.
Thanks.
OK first make a block how you'd like the coordinates and elevation displayed. Lets say the plock consists of a POINT entity, and 2 attributes, one with coordinates and second with elevation;
x1, y1
Elevation
The lisp routine would have user select all points, then do a 'substitution', replaceing the point with a block with attributes. Here's some code, will need debugging, input from you/others. You'll also need to insert your chosen block name on one line (line 18), and change scale as desired.
(princ "\nType Placecoords to start")
(defun C:Placecoords ()
(setq BkScale 1);edit to change scale of block insert
(setvar "attdia" 0);suppress dialogue box for attributes
(princ "\nSelect points to replace")
(setq PointSet (ssget '((0 . "POINT"))))
(setq NumPoint (sslength PointSet))
(setq Count 0)
(repeat NumPoint
(setq ename (ssname PointSet Count)
(setq PtCoord (cdr (assoc 10 (entget ename)))
(setq XVal (car PtCoord) 2 2)
YVal (cadr PtCoord) 2 2)
ZVal (caddr PtCoord) 2 2)
(setq CoordTxt (strcat (rtos XVal 2 2) ", " (rtos YVal 2 2)))
(setq ElevTxt (rtos ZVal 2 2))
(command "._-insert" "YourBlockName" PtCoord BkScale 0 CoordTxt ElevTxt);;edit for block name
(entdel ename)
(setq Count (1+ Count))
);repeat
(setvar "attdia" 1)
(princ)
);end defun
With some work it could look much better
(DEFUN C:TT () ; ID a point, place coordinates text
(graphscr)
(setq p (ssget)) ; Select objects
(setq l 0 n (sslength p)) ; Counter and quantitiy of objects
(while (< l n) ; For each selected object...
(if (= "POINT" (cdr (assoc 0 (setq e (entget (ssname p l))))))
(progn
(setq P1 (cdr (assoc 10 (setq e (entget (ssname p l))))))
(COMMAND "TEXT" P1 "" "" P1)
(setq l (+ 1 l)) ; Increment counter
) ; Close While and Progn
(terpri)
IF I HAVE, FOR EXAMPLE, A CIRCLE, I PRESUME I CAN EXCHANGE "POINTS" FOR "CIRCLE". IF SO, HOW DO I CHANGE THE LSP TO COPE WITH POINTS AND CIRCLES AND I SUPPOSE OTHER STUFF TOO - PRESUMING THE OTHER STUFF SUCH AS POLYINE WILL ONLY SHOW ONE POINT (START I GUESS) OF THE WHOLE ENTITY.
THANKS AGAIN.
Find the data in:
AutoCAD developer Help
DXF Reference
Entities section
For a circle, these are the data:
0 Entity type
5 Handle
39 Thickness (optional; default = 0)
10 Center point (in OCS) DXF: X value; APP: 3D point
20, 30 DXF: Y and Z values of center point (in OCS)
40 Radius
210 Extrusion direction (optional; default = 0, 0, 1)
DXF: X value; APP: 3D vector
220, 230 DXF: Y and Z values of extrusion direction (optional)
For a polyline, there may be multiple 10,20 and 30 entries for each point. I'm not sure.
