Old steel shed certification
Hi fellows
A question about old steel shed certification. How can I find out the steel capacity under corrosion.
Thank you.
Thank you.
RE: Old steel shed certification
If the corrosion is not much more than surface rust it could be ignored I think.
A question like this which is not directly related to an AS could be posted in the 'structural eng other topics' forum eg, where you would get a lot more replies.
John
