Empirical Masonry Design
I have a question I'm hoping someone can shed some light on...I am designing a small 50'x40' structure with masonry walls and a timber framed roof (plywood sheathing/wood trusses).  The wind speed and other factors are such that I am allowed by the IBC to use empirical design for the masonry.  This structure has a gable roof with a 10' eave but the height at the gable end extends to almost 21' at the ridge.  Using empirical design, I have no trouble getting an 8" block size to work along the eave edges (meeting h/t of 20 or 18).  However, at the gable end this requirement leads to a 12" or larger block.
First off, I would assume that the h/t requirements apply to the gable end as well as the sides supporting the truss bearing.  What is the typical framing used to get an 8 or 10" block to work at the gable end?  If a gable-end truss is used to terminate the masonry at 10', is there anywhere I can find details for connecting the truss to the top of the CMU; as well as how to brace the gable truss back to the roof sheathing for out of plane loading?  Is there a different detail that typically be used?
RE: Empirical Masonry Design
I would reinforce the CMU at the gable end for the entire 21' height.
If you must use a gable end truss, there are two options.  You could provide OSB for all or part of the ceiling, thus creating a flat diaphragm that braces the end wall at 10'.  Or you could provide diagonal 2 X 6's to brace the top of the CMU up to the roof diaphragm.
DaveAtkins
Thank you very much for your help.  I have one other question:  If I engineer the masonry at the gable end, do I design for the full ridge height as your answer above seems to suggest? Or is there an intermediate height between the eave and ridge heights it is designed for?  I haven't been able to find much literature on this.  Thanks again.
The literature always seems to avoid the tough questions.  I would design to the the eave plus 2/3 the difference.  After all, the wall will not fail in tiny strips, but as a whole.
Thanks, that seems to make sense.  The local highway department here states that sloped retaining walls should be designed for the height at 3/4 distance from the low point to the hight point along the length of the wall for that very reason.  I figured it might be something similar.
I would have designed for the full height, but what jmiec says makes sense.
DaveAtkins
