Solidworks-Drawing Template
I seem to have lost the Drawing Template in Solidworks, how do I get this back?
RE: Solidworks-Drawing Template
Try running a repair on your SW that should place the default templates back int if you lost the actual file.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I tried to open the mooload file and it was grinding pretty bad.
Here is a past thread that might help you thread559-120067
At some point you just have to shoot the engineer and build the dang thing.
Instead of making a bitmap file dsgnr1 make a jpg file it maintains high resolution but is small in size.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
You might want to try searching for the template on your hard drive because on one crash I had many moons ago I lost the "link" to where the templates were located.
search for *.SLDDRT
On a side note, I have a folder simply called "Solidworks Templates" saved in a location other than the SW install location that has all of my custom drawing, part, assembly, blocks, dimension favorites, etc.  If I uninstall SW, I don't lose any custom files.
Flores
SW06 SP2.0
If you had created any drawing recently, you can use that to make a new template.
Bradley
