SIMON error
SIMON error
SIMON error
I am working on a steel girder design using SIMON.  I have a girder that works, however SIMON will not complete the analysis of the stiffeners and bearings.  The program says starting stiffener design, then says
"Bad Utype: Abnormal program termination: Device not available."
Does anyone know what causes this error, or how to fix it?
RE: SIMON error
I would not hesitate to contact AISC on this matter, they are exceptionally responsive with their products.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
RE: SIMON error
Our contact there is on vacation for this week apparently, so I was hoping someone else may have met this problem before.
I believe the problem has something to do with having a hinge in the girder, since it runs fine if i remove the hinge.
