Sheetmetal Hem 0 radius ??
In sheetmetal Is there a way to get a zero rad. Hem? I keep on getting a .002 rad even when I select the closed option and I cant find what controls this.
thanks Tom..
thanks Tom..
RE: Sheetmetal Hem 0 radius ??
You cannot actually have zero because it would effectively merge with the main body, and you cannot have varying thickness in SW Sheet Metal parts.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Chris
Systems Analyst
AutoCAD 05
FAQ559-1100
FAQ559-716
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
Just thought you might be interested to know that I tried this in Solid Edge V15 and it produces a min gap of 0.0001575".
If you round this dimension to the 4th decimal it's 0.0002"
I'd suggest that the limitation is to do with what tolerance the systems can work to before they consider the faces to be coincident.
It's also possible that this is a limitation of Parasolid rather than SW or SE.
Producing the hem is simple in SE - it uses what they call a 'Contour Flange'. This lets you produce any shape of flange along all or part of an existing edge. All you do is draw a line representing the folded part, back along the face that you are folding down on to.
beachcomber.
PS.
.004" sheet!! that's for wrapping sandwiches in isn't it??
I tried to create a zero hem from a sketch and got the following alert: " The fillet could not be added because the specified radius would eliminate one of the elements".
Flores
SW06 SP2.0
But as I stated in an earlier reply, I am able to model this with sheetmetal by drawing a profile of the inside of the hem as a sketch with a .0001 rad and then using Base Flange to extrude it. It then unfolds as it should. Using the Hem tool may be more politically correct, but in this case I was able to work around it.
Thanks, Tom...
So it appears the Hem function has been ...
Jason
