Can you Repair Warehouse Shelving to meet OSHA Code?
We have an former OSHA Auditor tour our facility to give us advice to help us keep up with OSHA standards. One big problem we have is that we have several (40+) damaged warehouse shelving supports, (5600 lb capacity/beam_17K/rack). Having a time-limit to correct this problem and the costs of new shelving, do I have any options to fix this situation? And once I've corrected the problem, what are my options to maintain a safe shelving system.
Granted our current shelves/racks have been in place for quite a while, but our Forklift drivers don't necessarily "report" any damage that they might have done. I am looking into camera systems to enhance the awareness. Not to open a new can of worms, but we are trying to implement more lean manufacturing which would say, get rid of the shelves, but we have some product lines that make this situation infeasible. Where do I start?
Thank you,
jaeque
RE: Can you Repair Warehouse Shelving to meet OSHA Code?
Does anyone have any advice on protecting the new racks? I've scene Steel re-enforced guards dismantled, I've verified all forklift drivers have been trained within the last year, as well as threatened cameras; where should I start or re-emphasize? I just want to put a plan in place to hopefully prevent replacing these racks in the future. Our last racks haven't been manufactured for years, so replacing a few dismantled ones was out of the question. We started buying a new "Tear Drop" support.
Thank you,
jaeque
In terms of protecting your warehouse shelving, I've seen and used various options. Most options that work involve core drilling into your concrete pad and sinking a pipe filled with concrete (bullard) into the hole. You can do different things depending on the shelving area you are trying to protect. If you are trying to protect an area that is not in front of a pick location you sink two or more bullards and weld "C" Channel between the pipes. If you are in a pick location you sink the pipe directly in front of the column supports and allow room to get between the columns for picking. The key is that you need to sink the support into the concrete. Any solution I've seen that tries to anchor into the concrete and has a plate on the surface, ends up being sheared off over time. Hope this helps.
Rich.....
Richard Nornhold, PE
ampdesign@earthlink.net
