arc command vba
arc command vba
autocad2004 vba
trying to create an arc using
center point , start point , and total angle
can someone please help with the commands for doing this
thanks
thanks
RE: arc command vba
Sub Example_AddArc()
' This example creates an arc in model space.
Dim arcObj As AcadArc
Dim centerPoint(0 To 2) As Double
Dim radius As Double
Dim startAngleInDegree As Double
Dim endAngleInDegree As Double
' Define the circle
centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
radius = 5#
startAngleInDegree = 10#
endAngleInDegree = 230#
' Convert the angles in degrees to angles in radians
Dim startAngleInRadian As Double
Dim endAngleInRadian As Double
startAngleInRadian = startAngleInDegree * 3.141592 / 180#
endAngleInRadian = endAngleInDegree * 3.141592 / 180#
' Create the arc object in model space
Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngleInRadian, endAngleInRadian)
ZoomAll
End Sub
"Everybody is ignorant, only on different subjects." — Will Rogers
