hot water generation
Where can I find hot water generation guides (not steam).
Application: central hot water system for large buildng.
It will be a electrical system
RE: hot water generation
Look At: http://www.sussmanelectricboilers.com/svw1.htm
'makes no sense!
hydronic systems teaches about building space-heating using electrics or gas fired boilers,
genblr
Maybe just HW for sinks & such.
The application is electrical hot water generation for showers, bath etc..
you need a standard hot water heater.
ussually if you need more than 100 GL, you can install one or more heaters or one larger "generator" with a storage tank,
the system is similar to a gas fired but instead of generating the water heating with gas you use electricity.
It is not a rare situation.
www.steamequip.com supplies systems.. , I cheked the page iand is down now, I will check later.
genblr
