AutoCAD Generated Loop
I have a loop that is generated to an AutoCAD block. It is wired from MCC to DCS terminal strip to DCS Card. The wiring is correct as the ESL is correct and the CAD block tested correct.
Problem is that the loop info is backwards when CAD loop is generated. ie. DCS info on the left and MCC on the right.
If I view the loop point to point it is also backwards. Any suggestions??
RE: AutoCAD Generated Loop
the Seq should go up from the MCC to the DCS.
Tzvi
www.wise-assist.com
